July 27, 2023 at 5:08 am
Ha heongyu
SubscriberHi there, I am trying to plot the formability plot in LS-Dyna.
But something is strange.
Whatever mesh point i select, every value is zero.
So, every mesh point is pointed in origin in fld plot.
Why like this?
I designed the Punch, Plate, Die shell body, Is this the cause?
Please let me know why the values are all zero in every point.
July 31, 2023 at 5:54 pm
Imtiaz Gandikota
Ansys EmployeePlease run this simple example (https://www.dynaexamples.com/introduction/process_simulation/metal-forming-i) and see if you’re able to plot the data. Please also add *DATABASE_EXTENT_BINARY with STRFLG to output strain data to d3plot. If you still see zero values, maybe the issue is with your LSPP version. Try the latest LSPP version.
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7780
4508
2973
1449
1322
