March 5, 2023 at 8:28 am
kwak dongkyu
Subscriberhi i download above image ansys workbench. and i wanted to use ls-dyna that is in workbench
but when i tried to run the ls dyna the error message comes out like
'the demanded solver was not found in the specified path' what can i deal with it
do i also need to download the ls-dyna student version like below. thank you
March 5, 2023 at 12:25 pm
SubscriberYes, download LS-DYNA also.
March 6, 2023 at 12:46 am
kwak dongkyu
Subscriberbut it still didn't work..
March 6, 2023 at 3:07 am
SubscriberYes, but now you have the LS-DYNA solver installed. Go to the Start Menu and under ANSYS 2022R2 LS-DYNA Student select LS-Run. Use that to submit a .k file to the solver. Under that same folder is LS-PrePost that you can use to build a .k file of your model and look at the results.
Good luck!
March 6, 2023 at 10:45 am
kwak dongkyu
Subscriberthanks for your reply
but i want to ask you one more question.
can i export .k file in ansys? if i save the ansys file its file type is wbpj.
March 6, 2023 at 11:45 am
SubscriberI'm not an expert at LS-DYNA, I'm an expert at Workbench. I had a quick look in the free Ansys (Student) Workbench and in LS-PrePost and noticed that in Workbench, I can export a Nastran file and in LS-PrePost I can import a Nastran file. I often do meshing in a Modal analysis block and Export Nastran file then open that in Femap where I finish preparing the file to submit to the Nastran solver.
On a paid Ansys Workbench license, LS-DYNA is an analysis system that you can drag into the Project Schematic, just like you can with Explicit Dynamics. This feature is not included in the Student license.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3670
2552
1751
1226
582
