July 7, 2023 at 5:08 am
Fady Elshazly
SubscriberHello,
Is there any way to control the stiffness matrix formulation in LS-DYNA implicit. I mean to form it at the beginning of the solution and not to change it.
Is there any way to save only the results (displacement, velocity and acceleration) of specific nodes in an ASCII/text file directly without the need to open lsprepost again?
Thanks -
July 7, 2023 at 12:13 pm
Ram Gopisetti
Ansys Employeehi
elobrate your first point ( what method you are look for, etc)
try using the database_history_node (id, set)
in smp run it outputs nodeout which has following header with time stamp
nodal point x-disp y-disp z-disp x-vel y-vel z-vel x-accl y-accl z-accl x-coor y-coor z-coor
in mpp run it will be output in binout you can also check the elout database
cheers, ram
July 7, 2023 at 7:36 pm
Fady Elshazly
SubscriberI am using mpp and history node id. I need to save the recorded nodes in history node id in a file that can be red directly without the need to open lsprepost again. I mean to import it in matlab or something and read it as a txt or other readable extensions.
July 7, 2023 at 3:50 pm
Jim Day
Ansys EmployeeTo retain the same stiffness matrix for each step in a LINEAR implicit analysis, set NSOLVR= -1 (negative one) in *CONTROL_IMPLICIT_SOLUTION.
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7808
4508
2979
1453
1322
