September 21, 2022 at 8:10 pm
Todd Bredbenner
SubscriberI'm trying to run implicit jobs on ls-dyna on a ubuntu 20.04 workstation. (We have Academic Multiphysics Campus licenses for Teaching and Research.)
I started by using the GUI-based Ansys installer and ls-dyna (single precision) was installed. I get a run-time error that I implicit solver jobs are not supported on the single-precision solver version. I don't see an option (?) to specify which version of ls-dyna to install through the Ansys installer.
I downloaded the single precision SMP version of ls-dyna (R13.1.0), installed it using the attached shell script, and set up a LSTC_FILE pointing to the ansys license server. I get a run-time error that the Error License client cannot find any servers to talk to.
How can I resolve the ls-dyna version / licensing issue?
Thanks,
Todd
September 22, 2022 at 1:16 pm
George Karnos
Ansys EmployeeDo You have “ANSYS Academic Research LS-DYNA” product?
If not, “Academic Multiphysics Campus licenses for Teaching and Research” don’t support LS-DYNA solver.To enable LST LS-DYNA to run with Ansys licensing, set LSTC_FILE to ansys or ANSYS, then set ANSYSLMD_LICENSE_FILE environment variable to 1055@servername (servername of License server.) Also the licensingclient folder (which contains ansyscl) need to place in same directory as LST LS-DYNA executable file.
I recommend installing version 2022 R2 Service Pack 2 -
September 23, 2022 at 8:51 pm
Todd Bredbenner
SubscriberHmm. I thought that we discussed adding LS-DYNA support to our license, but maybe that didn't happen. I'll have to look into it.
At any rate, thanks for your help, George!
- Workbench error
- Workbench not opening
- License Error
2524
2066
1285
1096
459
