Ansys Products
Ansys Products
LS-DYNA license issue
    • goonewardena
      Hi, I'm trying to run a .k file on LS-RUN, and I'm encountering the attached error. I got the solver from ANSYS student version.
      However, LS-DYNA is not appearing in the Analysis Systems on ANSYS WB. Please help :)
    • George Karnos
      In the Windows search field on the task bar, type in Environment
      Open "Edit System Environment Variable for your system"
      Click on Enironment Variables:
      Click on New and Add the System Variable: ANSYS_SYSDIR
      Now try to run LSRUN
      For available in WB: If you click on View All/Customize
      Is LS-DYNA available?
      Did you install LS-DYNA Student or are you running Academic versions with a teaching or research license?
