LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
LS-Dyna License Manger – Network License Registration
    • Brian Kearns
      We are trying to create the LSTC_SERVER_INFO file to send to Ansys in order to get new license file. We are using the instructions provided.  However, the file that gets generated is 0 bytes and contains no information.  Here are the instructions we followed.  Please advise.  Thanks, Brian
      Windows:
      Install the complete LSDYNA package (500MB) which includes the LSTC License Manager
      Download:
      https://ftp.lstc.com/user/pc-dyna/R111/smp/CompleteInstal/
      User Name: user
      Password: computer
      After you have installed the full LSDYNA package:
      • Open the LS-DYNA Program Manager
      • Go to "License Manager Menu"
      • Click Registration
      • Save and send the SERVER_INFO FILE to ANSYS to request/process your license.
    • Andreas Koutras
      Hello, could you also try with LS-RUN. Here is a tutorial:
      https://www.youtube.com/watch?v=ymkTJCefm30&t=233s
    • Reno Genest
      Hello Brian,
      You can use LS-RUN as follows:
      You can download LS-RUN here:
      https://ftp.lstc.com/anonymous/outgoing/lsprepost/LS-Run/win64/
      Note that LS-RUN also comes with the latest releases of Ansys Workbench.
      Reno.
    • Reno Genest
      Hello Brian,
      We usually use the latest LSTC license manager to generate the LSTC_SERVER_INFO file. Here is the latest procedure:
      https://ftp.lstc.com/user/license/License-Manager/LS-DYNA%20Win%20License%20Server%20installation%20and%20update%20Aug%2026_2.pdf
      username: user
      password: computer
      Let me know how it goes.
      Reno.
    • Reno Genest
      Hello Brian,
      If this does not work, you will have to generate the license file in manual mode using the gmid.exe program located in the LSTC license manager installation directory. Here is the procedure:
      1. Open command prompt as administrator.
      2. Cd to the gmid.exe directory.
      3. Run the gmid.exe program:
      4. Copy all the output text to a text editor and replace "MACHINE" for "SERVER". Here is the example for my machine:
      SERVER: 88 F5 74 7A 7E10E0ED F3A4AC8C 642A5357 27BCFCEE
      #        88 F5 74 7A B70043CA CB442F85 FD629C6D 1434EE84
      # Intel(R) Ethernet Connection (7) I219-LM (DOWN)
      SERVER: CD FC AD 36 ED0607D7 2255BA11 7B416CDA D2F570E4
      #        CD FC AD 36 865F796F 2492E23A 2D74D6E4 4F2A0862
      # Bluetooth Device (Personal Area Network) (DOWN)
      SERVER: BB A6 B0 00 1386DBF0 161AAC52 3ADC254E C29DED6C
      #        BB A6 B0 00 B72A5BE1 2FBE9331 4CC195DE B5ADEBAA
      # Check Point Virtual Network Adapter For Endpoint VPN Client (DOWN)
      SERVER: D1 FC AD 36 696C061D 4B53D8FD 2FD032CB C42BF148
      #        D1 FC AD 36 E72CC0F2 EAEA7599 884C89BC 66D50403
      # Intel(R) Wi-Fi 6 AX200 160MHz (UP)
      SERVER: D0 FC AD 36 7C940605 45CFA9B1 705AEB85 59E3FB38
      #        D0 FC AD 36 1BB06D99 1934EECD 9A7CAC64 AB9F82D3
      # Microsoft Wi-Fi Direct Virtual Adapter (DOWN)
      SERVER: D1 FC AD 34 D63AFE94 168307E3 2C8E197A 26A98E36
      #        D1 FC AD 34 7597B1C3 372CA516 EA72EE5C EACD54CB
      # Microsoft Wi-Fi Direct Virtual Adapter #2 (DOWN)
      SERVER: 06 59 77 E1 8AD6FA51 D895E688 4F78F613 194E0D6E
      #        06 59 77 E1 AE5C4CD1 1B643273 639FA3A8 DD9334FE
      # Generic (UP)
      # Number of CPUs:12
      # ProductId     : No ProductId Information
      # 0: 16 756e6547 6c65746e 49656e69
      # 1: 906ed 100800 9efaf387 bfebfbff
      # 2: 76036301 f0b5ff 0 c30000
      # 4: 1c004121 1c0003f 3f 0
      # 6: 71 2 9 0
      # 9: 0 0 0 0
      # 10: 7300404 0 0 603
      # 11: 1 2 100 0
      # 13: 0 0 0 0
      # e0: 80000008 0 0 0
      # e1: 0 0 1 2c100800
      # e2: 65746e49 2952286c 726f4320 4d542865
      # e3: 37692029 3538392d 43204830 40205550
      # e4: 362e3220 7a484730 0 0
      # e6: 0 0 1006040 0
      # e7: 0 0 0 100
      # e8: 3027 0 0 0
      5. Save the text file as LSTC_SERVER_INFO and send it to your Ansys account manager to cut the key.
      Reno.
Viewing 4 reply threads
