February 1, 2021 at 8:03 am
Ansh
SubscriberWill LS-Dyna and LS-Prepost licenses reflect in the Ansys License Management Center and the Ansys Licensing Portal for server based licenses?n -
February 1, 2021 at 1:47 pm
ANSYS_MMadore
Ansys EmployeeOnly licenses served under the ANSYS License Manager would be listed. The LSTC LSDyna licenses would not.nnThanks,nMattn -
February 1, 2021 at 3:02 pm
Ansh
Subscriberthanks for the update. If you could help me understand then how can we see the usage and licensing position of LS Dyna? Could you share some guide/video for the same, would really help a lot. n -
February 5, 2021 at 8:01 pm
tslavik
Ansys EmployeeLS-PrePost does not require a license.nnFor LS-DYNA, if you are using the LSTC License Manager, and if you are saving a license log, then you can use the lstc_logreport utility to extract usage information. I'm not sure it will give you everything you want, but give it try. Execute the program with no arguments to print a SYNTAX statement:nnSYNTAX:./lstc_logreport input_logfilen [-begin MMDD[[YY]YY]] [-end MMDD[[YY]YY]]n [-sort [user|host|program|status]] [-rev]n [-csv]n [-out out_file]nnThe input_logfile should be the name of file specified as the log file for the LSTC License Manager. The Window version automatically uses lstclm.log as its log file. Linux/UNIX servers require you to specify the name on the command line using a -l option (i.e., lstc_server -l logfile_name). The output has a simple format. Use -csv to save in a format that can be imported into Excel.n
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5290
3299
2469
