July 7, 2023 at 8:12 pm
Fady Elshazly
SubscriberHello,
I am solving model explicitly and the input motion has a time step of 0.005 sec. I am trying to record the nodout in ASCII database at dt=0.01 sec and dt=0.0001 sec. Both models give different results. Is the nodout dt used in input interpolation and then used in the analysis? or what would make this difference.
Thanks
July 10, 2023 at 3:23 pm
Andreas Koutras
Ansys EmployeeHello, output cannot be generated at time intervals less than the timestep size of the analysis. The smaller output time interval can output a higher frequency of the response. However, the results at the same time instances should be the same in the two cases.
July 10, 2023 at 7:33 pm
Fady Elshazly
SubscriberThe analysis time step is 1*10-5 which is smaller than the two cases. The dt i am using to generate the output is used only for the nodeout and is smaller than the one for the d3plot. can this cause the results difference?
July 11, 2023 at 12:16 pm
Andreas Koutras
Ansys EmployeeHello Fady,
Please see the above reply:
The smaller output time interval can output higher frequencies of the response. However, the results at the same time instances should be the same in the two cases.
July 11, 2023 at 6:53 pm
Fady Elshazly
SubscriberThank you so much
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7818
4514
2979
1453
1322
