LS Dyna
LS Dyna
LS-dyna perturbation_node
    • minchunh
      I'm using perturbation_node type 3 (read perturbations from a file) to define a perturbation over the model. Here's the file I modified the output data from implicit_buckle analysis:
      *KEYWORD
      $TIME_VALUE = 3.78E+01
      $STATE_NO = 1
      $Output for State 1 at time = 37.7669
      $NODAL_DISPLACEMENT
      $ NID x-disp
      1 -1.44E-02
      2 -1.70E-01
      3 9.66E-02
      4 3.23E-07
      5 -9.61E-02
      6 -1.43E-07
      7 2.93E-07
      8 -9.66E-02
      9 -1.25E-01
      10 0.00E+00
      11 1.40E-01
      12 9.66E-02
      13 1.64E-06
      14 0.00E+00
      15 -2.83E-06
      16 1.18E-06
      17 1.18E-06
      18 0.00E+00
      19 1.70E-06
      20 3.78E-08
      21 -1.70E-06
      22 0.00E+00
      23 3.78E-08
      24 6.86E-07
      25 -1.01E-02
      26 -1.81E-01
      27 0.00E+00
      28 -4.71E-03
      29 1.16E-06
      30 -9.66E-02
      31 5.10E-02
      32 1.51E-06
      33 1.16E-06
      34 -3.73E-06
      35 -1.76E-02
      36 1.76E-02
      37 0.00E+00
      38 -1.40E-01
      39 0.00E+00
      40 1.76E-02
      41 -6.30E-02
      42 -3.45E-02
      43 5.09E-02
      44 3.23E-07
      45 1.70E-01
      46 -6.74E-02
      47 -5.09E-02
      48 0.00E+00
      49 3.48E-02
      50 1.01E-02
      51 -3.48E-02
      52 1.58E-06
      53 0.00E+00
      54 -3.73E-06
      55 -5.10E-02
      56 7.07E-07
      57 6.61E-02
      58 4.71E-03
      59 9.61E-02
      60 -5.10E-02
      61 6.86E-07
      62 6.63E-07
      63 -1.70E-01
      64 -1.01E-02
      65 0.00E+00
      66 -3.48E-02
      67 8.38E-08
      68 1.74E-06
      69 1.74E-06
      70 3.45E-02
      71 1.51E-06
      72 0.00E+00
      73 1.25E-01
      74 4.71E-03
      75 -9.61E-02
      76 3.48E-02
      77 -3.45E-02
      78 6.30E-02
      79 0.00E+00
      80 -1.76E-02
      81 2.19E-08
      82 1.17E-01
      83 6.63E-07
      84 0.00E+00
      85 0.00E+00
      86 1.17E-06
      87 -6.62E-02
      88 6.30E-02
      89 1.17E-01
      90 5.10E-02
      91 9.61E-02
      92 -6.62E-02
      93 1.01E-02
      94 -4.07E-06
      95 0.00E+00
      96 0.00E+00
      97 0.00E+00
      98 -1.40E-01
      99 1.58E-06
      100 -4.71E-03
      101 1.44E-02
      102 2.62E-07
      103 -7.18E-07
      104 1.40E-01
      105 -1.70E-06
      106 5.09E-02
      107 -1.17E-01
      108 0.00E+00
      109 -5.09E-02
      110 -6.30E-02
      111 6.61E-02
      112 0.00E+00
      113 0.00E+00
      114 -1.43E-07
      115 7.07E-07
      116 7.19E-07
      117 6.74E-02
      118 -2.83E-06
      119 3.45E-02
      120 8.38E-08
      121 4.05E-08
      122 -1.17E-01
      123 2.41E-07
      124 -7.18E-07
      125 1.44E-02
      126 -1.44E-02
      127 0.00E+00
      128 2.19E-08
      129 2.62E-07
      130 1.18E-06
      131 1.55E-06
      132 4.05E-08
      133 2.41E-07
      134 2.93E-07
      135 1.55E-06
      136 1.17E-06
      137 1.81E-01
      138 7.19E-07
      139 1.70E-01
      140 0.00E+00
      141 1.58E-06
      142 1.18E-06
      143 1.58E-06
      *END
      The file works successfully when using an older solver, e.g. R8.0.0 but the analysis terminates with an error as follows when using the solver R11.1.0:
    • Imtiaz Gandikota
      I don't think the format has changed. Please try a different version or import the file into LSPP as user-defined nodal results to check if its read correctly.
      You can also use csv format for the values (1,-1.44E-02).
