February 1, 2023 at 10:42 am
Mahmoud_87
SubscriberDear All,
How to use a Prestressed LS-Dyna analysis? I need to use the date of static structure in LS-Dyna wrkbench module.
February 1, 2023 at 2:18 pm
Ram Gopisetti
Ansys EmployeeHi, with the new versions of ANSYS 2022 and above, you can bing the dynain file which has the prestress data but this is corrsponding to lsdyna to lsdyna, however, you can export the deformed shap and export the stress at last time step and use external data to map into LSDYNA. but recent update will allow you to read the dynain.k file into structural analysis via mechanical model.
Cheers, Ram
February 1, 2023 at 7:01 pm
Reno Genest
Ansys EmployeeHello,
There are a few ways to calculate prestress in LS-DYNA. You could use explicit dynamic relaxation directly in WB LS-DYNA (no need to do an Ansys Static Structural analysis). This will use the LS-DYNA explicit solver to apply preload.
If you right click on the Dynamic Relaxation object in Mechanical, you will have options to add General preload (gravity, etc.) and bolt pretension.
Dynamic relaxation is an analysis that occurs before time 0 to apply the pre load and calculate prestress. Explicit dynamic relaxation is similar to performing an explicit dynamic analysis with some damping to find the static equilibrium under pre loads before time 0. We call this pseudo time.
Explicit dynamic relaxation is a good option if the preload is highly nonlinear and/or if you have rigid body motion. Using an implicit solver will not work well or not at all for those cases.
You will find more information here:
http://ftp.lstc.com/anonymous/outgoing/support/FAQ_docs/preload.pdf
Reno. -
February 1, 2023 at 7:07 pm
February 1, 2023 at 7:14 pm
Reno Genest
Or you could apply the preload using Ansys Static Structural and connect to an LS-DYNA system in WB:
In this case, in LS-DYNA Mechanical, you have to set the Dynamic Relaxation to "Explicit After Ansys Solution":
You will find more information in the Ansys documentation:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/lsdyna_ug/exd_ag_lsdyna_DR_kwds.html?q=dynamic%20relaxation
Let me know how it goes.
Reno.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5454
3419
2473
1310
1022
