March 7, 2023 at 10:29 am
G.Troulliotis
SubscriberDear all,
I received the SMP DP R14 version of LS-DYNA through secure transfer, for both Windows and Linux.
The object version when compiled in Windows works as expected. The same object version when compiled for Linux (HPC application) throws a license error (see below).
The models were run on a single node of the HPC (40 cores) for which LS-DYNA SMP DP R13 works. The Windows R14 object version, points to the same license server and also works.
Have you had any such issues in the past?Best Regards,
George
March 7, 2023 at 9:07 pm
Reno Genest
Ansys EmployeeHello George,
Do you have the same LSTC license manager for both Windows and Linux client machines? Which option revision do you have in the license file? Do you have the R14 option? See image below for example:
If you don't have the Revision 14 option in the license file, you won't be able to run R14. You will need to request a new license file with the R14 option in it.
Let me know how it goes.
Reno.
March 8, 2023 at 5:22 pm
G.Troulliotis
SubscriberHi Reno,
I have relayed the above information to the admin of the license server/HPC facilities and I will let you know when I have a reply.
Best Regards,
George
March 17, 2023 at 11:45 am
G.Troulliotis
SubscriberHi Reno,
We were unable to find such an indicator in our license manager, we are using the Ansys license manager instead of the LSTC license manager. I have spoken to our account manager in Ansys who might be able to help sort out the issue.
I apologise for the delay.
Many Thanks,
George
March 17, 2023 at 3:24 pm
Reno Genest
Can you send me the LS-DYNA banner screenshot for the run on Linux with the R14 object file? Is this solver enabled for the Ansys license? See example below:
If the solver is not ANSYSLIC enabled, then it won't work with the Ansys license. In this case, we will have to recompile another solver and send it to you.
Reno.
[8:18 AM] Prashant Kale (External)
And request the customer to send test email to your id
March 17, 2023 at 4:02 pm
March 17, 2023 at 4:45 pm
Reno Genest
Are you pointing to the same license server on Linux as you do on Windows? What is the LSTC_LICENSE environment variable set to on Linux? You are using the exact same version of LS-DYNA on Windows and Linux and so it should work on both.
Is this the only error message you get?
Can you send me the messag file by email?
I don't handle Ansys licensing issues; only LSTC licenses. Let me check with a colleague if he can help with this problem.
I think the best would be to file an SR for this problem and have someone from our installation and licensing support group have a look.
Reno.
March 17, 2023 at 5:00 pm
Reno Genest
My colleague says he would have to check the Ansys licensing log on the Linux machine. Ansys employees are not allowed to upload and download files on the Ansys Forum.
So, you will have to file an SR for this problem. The SR should go to the installation and licensing support group and not to me.
Reno.
March 17, 2023 at 5:06 pm
G.Troulliotis
SubscriberDear Reno,
Thank you very much for the help, I will submit an SR.
Best Regards,
George
March 17, 2023 at 5:07 pm
Reno Genest
Sounds good.
Have a good weekend!
Reno.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3812
2593
1849
1244
600
