LS Dyna
LS Dyna
LS – Dyna Restart, without having “d3dump01” but the files from d3dump01.0001 and d3dump01.0063
    • elisa.peroglio
      Hello, I have some troubles in running the Ls - Dyna simple restart. In my model there is not cyclical print of a d3dump (the CYCL is equal to 0.0 in the keyword BINARY_D3DUMP), in fact at the end of the simulation I only have d3dump01.
      But the problem is that I don't have exactly the file "d3dump01" while I got 63 files, I think each regarding one single submodel. So how am I suppose to restart the simulations? Running "r=d3dump01", as manual tells, the simulations don't start because it's not finding the file d3dump. I don't think it is correct to launch "r=d3dump01.0063" because I think it is taking only the 63th submodel.... Do you know if there is a way to restart in this conditions? Maybe there is a way to restart by specifying all the 63 d3dumps together?
    • Andreas Koutras
      It seems you're running MPP with 64 cores. To do a simple or a small restart in MPP (details in Manual Vol I, under "Restart Input Data"), please add the command "r=d3dump01" in the execution line. Note that in the restart analysis you must use the same number of cores as in the previous run. The d3dump01.0000 - d3dump01.0063 files need to be in the directory of restart run.
      For example, if you're using Intel MPI, the execution command for a small restart would look like:
      mpiexec -n 64 mppdyna_exe i=restart_input.k r=d3dump01
      I hope this helps.
    • elisa.peroglio
      Hello, thank you very much! So I can use the syntax "r=d3dump01" even if the file "d3dump01" doesn't exist? (while are existing the d3dump01.0001 etc...). And if I'm doing a simple restart, the "restart_input.k" can be the .k file that was used for the very first start of the simulation? Or I have to modify it somewhere?
      Thank you a lot!
