August 24, 2022 at 12:55 pm
elisa.peroglio
SubscriberHello, I am simulating six different types of side crashes. While for 3 left crashes and 2 right crashes the simulation is going well, for the one at the right of the vehicle, at right angle in corrispondence of R point, the simulations ends before the termination time is reached. I can't see in log file any errors, at the end it is only saing:
E r r o r t e r m i n a t i o n
430565 t 4.4592E+01 dt 4.00E-07 flush i/o buffersDo someone have an idea of why this is happening? I see that the energy is balanced and also hourglass is very low. Could you advise me what else I can check? It seems very strange to me, since the other five simulations are running correclty.
Thank you!
Elisa
August 25, 2022 at 3:38 pm
Reno Genest
Ansys EmployeeHello Elisa,
Are you running MPP on many cores? If so, have a look at each messag files (messag0000, messag0001, etc.). A meaningful error message may be written in one of the files.
Reno.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2656
2120
1347
1118
461
