November 27, 2022 at 11:16 pm
Aulia Arifin
SubscriberHi, I'm currently conducting research on various beam-column precast concrete connections, and I'm still confused about which is the best material model for steel with yield strength up to 500 MPa (that is available in LS-DYNA) that can capture well the steel material cyclic behavior. Please give me suggestion.
November 28, 2022 at 1:06 pm
Ram Gopisetti
Ansys EmployeeHi , you have *MAT_080( from your paper) , *MAT_125,*MAT_153,*MAT_165,*MAT_226,*MAT_242 to model cyclic behaviour.
Cheers, Ram
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2666
2120
1349
1132
461
