September 8, 2023 at 5:53 am
Yuju Chen
SubscriberI used Python to trigger LS-PrePost to execute a .cfile in batch mode. Everything works well on my laptop.However, when I execute my Python code on the server, LS-PrePost crashes without any apparent reason. Has anyone had a similar experience?
September 8, 2023 at 2:55 pm
Imtiaz Gandikota
Ansys EmployeeDid you try running LSPP in batch mode on the server first, without using python? What command are you running? There are couple of options, as shown below. If the first command does not work, try the second. I also suggest using the latest LSPP version.
/path/lspp410 runc=cfile
/path/lspp410 -nographics c=cfile
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7742
4502
2963
1449
1322
