Ansys Products
Ansys Products
LSDYNA binary results file
    • Fady Elshazly
      I am trying to record the response at large number of specific points IDs in an LSDYNA model using history node id keyword in a shape of binary file. I have checked the DPF package and it is not possible to use it for reading the LSDYNA binary file. Is there any way to convert this binary file to a txt or csv or ascii file directly without opening lsprepost again. I mean a script to be used in the terminal or any other suggestion that makes it more automated process. Please, if there is a way to do this, provide the detailed process.
      Thanks
    • Ram Gopisetti
      try to use third part api at https://pypi.org/project/dynareadout/
      or try with the exampes described in the following link
      https://dpf.docs.pyansys.com/version/stable/examples/01-transient_analyses/02-lsdyna_operators.html#sphx-glr-examples-01-transient-analyses-02-lsdyna-operators-py
      cheers, ram
