July 28, 2023 at 7:12 am
Zhang Zihui
SubscriberHi all, I am using LsDyna for cutting simulation:
The area being cut is using Solid-SPG, the tools are rigid bodies and the contact between them is using Autonomic_Nodes_to_Surfaces.
The simulation results show that the SPG particles receive the contact force, but they don't move, they stay in place and penetrate the tool surface.
Does anyone have any guidance on how this should be solved? Thanks! -
August 2, 2023 at 1:56 pm
Ashish Kumar
Forum ModeratorHi,
If you try doing a web search with following keywords - LsDyna Cutting Simulation SPG Particle Penetration
then you may be able to find some relevant videos.
Ashish Khemka
August 2, 2023 at 1:58 pm
Ram Gopisetti
Ansys EmployeeHi,
Try with non automatic node to surface contact with increased stiffness factors and use 4,3 types.
try using kernel 1 with ITB =3 and use SMSTEP =5 or lower in section SPG.
chers, Ram
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7742
4502
2961
1449
1322
