March 14, 2022 at 5:00 am
Swanand107
SubscriberHello ,
1) I Was using LS-DYNA Version R11.0.0 = My Setup was running.
2) But when i switched to R11.1.0 = Solver Gave error ( ( Error unresolved symbol: "D")
(Error 10907 (KEY+907)
*** Error unresolved symbol: "D")
I am not able to understand , how can i remove this error
If anyone is aware that would help
March 14, 2022 at 8:48 pmImtiaz Gandikota
Ansys EmployeeThis is an input error. My guess is you have an input field with "&D" without *PARAMETER card defined. Try to read the file in LS-PrePost and check if points to the card with error.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2616
2092
1321
1108
459
