August 16, 2022 at 8:21 pm
ridenour
SubscriberMy school has this license, " ANSYS Academic Multiphysics Campus Solution (25/250) "
When launching Ansys, I am able to select the license labeled "Ansys Mechanical Enterprise". All of the Ansys modules appear to be running fine, license checkouts are good. But trying to use the LSDYNA module causes this error pasted below. Any ideas? Thanks!
August 17, 2022 at 4:12 pm
George Karnos
Ansys EmployeeANSYS Mechanical Enterprise will not allow LS-DYNA to run, You would need to choose a Dyna license.
How are you choosing the license? -
August 17, 2022 at 7:27 pm
August 24, 2022 at 3:49 pm
George Karnos
Ansys EmployeeClick on "Reset to Default"
Does LS-DYNA now show up in the list?
Choose it and move it to the top.
Exit Mechanical, then go back in.
September 16, 2022 at 2:48 pm
ridenour
SubscriberClicking Reset to Default (and restarting app) did not add LSDyna to the list.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2724
2146
1357
1150
462
