July 12, 2022 at 10:41 pm
crd73
SubscriberHi, I hope to gather assistance in troubleshooting two issues.
1st - One day LSDYNA and the corresponding license work perfectly, and the next, the license manager gives an error such as that "Machine ID: X does not match the license file id: Y" (Image 1). Why would the machine ID change on either the machine or the license, and how can I troubleshoot this?
2nd - The next day, the license manager (lstclmui.exe) won't start, giving a C++ error (Image 2) I was able to access another license manager interface through LS-Run (not sure of the difference) and when I select the "install network license" option and select the file that worked recently on the same machine, I receive the error in image 1.
July 20, 2022 at 9:20 pm
Reno Genest
Ansys EmployeeHello,
Is your LSTC license server a virtual machine (VM)? VMs are prone to hostid changes as seen by the LSTC license manager and so we recommend installing the LSTC license manager on a physical (bare metal) server.
The error message you are getting means the hostid of the LSTC license server does not match the hostid in the license file (server_data). To fix this problem, you usually need to do a license server change (sign an LCF form) and get a new license file. Please contact your Ansys account manager to get a new license file.
Have you installed the program manager? If so, please uninstall it and all LSTC products and use the LSTC license manager on the license server and LS-RUN on the client machine to run LS-DYNA.
Have you installed the latest LSTC license manager on the license sever? You can download it here:
https://ftp.lstc.com/user/Download-Instructions/Job-License-Manager/
username: user
password: computer
After installing the LSTC license manager on the license server, run the lstclmui.exe as administrator and uninstall and then install the LSTC service for Windows:
Then, you can import the license file:
And start the service:
You will find all the LSTC license manager documentation here:
https://ftp.lstc.com/user/download-instructions/License-Manager/LSTC_LicenseManager-InstallationGuide.pdf
You can download LS-RUN here:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/LS-Run/
And you will find a video tutorial on LS-RUN here:
Finally, you can download the latest LSPP here:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/4.9/
Let me know how it goes.
Reno.
October 20, 2022 at 4:31 pm
crd73
SubscriberThanks! Requested another license with the new ID and will see how that goes.
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3850
2613
1853
1246
600
