Ansys Products
Ansys Products
Lumerical 2022 R1.4 floating license not running
    • jev1
      Good day,
      I've updated the version of my Lumerical and the new installation cannot find the running licenses from my floating server. I doubled checked the configuration of the address and port it all seems correct. Also if a run Lumerical 2022 R1.0 it works perfectly fine.
      In addition when I run version 2019b, which I need because it's currently the only one that works in our HPC, the license suddenly stopped working.
      When I check the license manager status I have plenty of licenses available, I am copying here below the reply to lmstat
      I appreciate your help.
      Juan
      lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
      Flexible License Manager status on Mon 6/13/2022 15:41
      [Detecting lmgrd processes...]
      License server status: 27011@10.230.10.33
        License file(s) on 10.230.10.33: licenses\LUMERICL\start.lic:
      10.230.10.33: license server UP v11.16.2
      Vendor daemon status (on M-DCWAP-P001-LB):
      LUMERICL: UP v11.16.4
      Feature usage info:
      Users of start:  (Total of 1 license issued;  Total of 0 licenses in use)
      Users of automation_api:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of charge_solver:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of dgtd_solver:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of eme_engine:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of fde_engine:  (Total of 15 licenses issued;  Total of 0 licenses in use)
      Users of FDTD_Solutions_design:  (Total of 10 licenses issued;  Total of 1 license in use)
      "FDTD_Solutions_design" v1.0, vendor: LUMERICL, expiry: 22-jan-2023
      floating license
        Photonics DESKTOP-27TFSEM DESKTOP-27TFSEM (v1.0) (10.230.10.33/27011 113), start Mon 6/13 10:49
      Users of FDTD_Solutions_engine:  (Total of 20 licenses issued;  Total of 1 license in use)
      "FDTD_Solutions_engine" v1.0, vendor: LUMERICL, expiry: 22-jan-2023
      floating license
        Photonics DESKTOP-27TFSEM DESKTOP-27TFSEM (v1.0) (10.230.10.33/27011 477), start Mon 6/13 15:06
      Users of heat_solver:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of INTERCONNECT_block_mode:  (Total of 10 licenses issued;  Total of 0 licenses in use)
      Users of INTERCONNECT_std_element_lib:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of INTERCONNECT_S_parameter:  (Total of 10 licenses issued;  Total of 0 licenses in use)
      Users of laser_library_extension:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of layout_ide:  (Total of 15 licenses issued;  Total of 0 licenses in use)
      Users of Lumerical_INTERCONNECT_design:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of Lumerical_INTERCONNECT_engine:  (Total of 10 licenses issued;  Total of 0 licenses in use)
      Users of MODE_Solutions_design:  (Total of 5 licenses issued;  Total of 1 license in use)
       "MODE_Solutions_design" v1.0, vendor: LUMERICL, expiry: 22-jan-2023
       floating license
       bp64 ADUAEI10986LPWX ADUAEI10986LPWX (v1.0) (10.230.10.33/27011 1016), start Mon 6/13 15:39
      Users of system_library_extension:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of topology_toolbox:  (Total of 5 licenses issued;  Total of 0 licenses in use)
      Users of varfdtd_engine:  (Total of 15 licenses issued;  Total of 0 licenses in use)
      Flexible License Manager status on Fri 6/17/2022 12:43
      Feature usage info:
      floating license
      Photonics DESKTOP-27TFSEM DESKTOP-27TFSEM (v1.0) (10.230.10.33/27011 1275), start Fri 6/17 12:08
      Users of FDTD_Solutions_engine:  (Total of 20 licenses issued;  Total of 0 licenses in use)
      Users of MODE_Solutions_design:  (Total of 5 licenses issued;  Total of 0 licenses in use)
    • Lito Yap
      @Juan,
      From your license status, you are running the Legacy Lumerical FlexNet license manager. These licenses do not support the 2022 R1.4. You can use prior releases for this version of the license manager.
