March 24, 2021 at 4:05 pm
vlad_p
SubscriberHello, nI am trying to run a simulation of a circular bragg grating however when I set it to run, the program does not get past the initialisation stage and crashes with the following report:nC:\Program Files\Microsoft MPI\Bin\mpiexec.exe -n 6 C:\Program Files\Lumerical\v211\bin\fdtd-engine-msmpi.exe -t 1 C:/Users/Vlad/Downloads/final_structure.fspnjob aborted:n[ranks] messagen[0-2] terminatedn[3] process exited without calling finalizen[4-5] terminatedn---- error analysis -----n[3] on DESKTOP-AFAVULJnC:\Program Files\Lumerical\v211\bin\fdtd-engine-msmpi.exe ended prematurely and may have crashed. exit code 0xc0000409n---- error analysis -----nnany help will be much appreciated!n -
March 25, 2021 at 11:37 pm
Lito Yap
Ansys Employee,Can you try to run the mwp.fsp example from this article ? If the error happens with the example, mwp.fsp, try to run the simulation using Local Computer as your Job launching preset. See this post on running jobs without MPI. Otherwise if the issue only occurs with your simulation, check and make changes to your simulation/project. n
Trending discussions
- Error on Lumerical device
Top Contributors
2656
2120
1349
1118
461
Top Rated Tags
