Photonics
Photonics
lumerical fdtd command write() doesn’t seem to behave as intended – “overwrite” not acknowledged
    • mfeinst
      I want to write files from Lumerical data, but I want to overwrite previous content files if applicable. From online documentation (https://support.lumerical.com/hc/en-us/articles/360034411134-write-Script-command) that should be possible by adding "overwrite" in the function arguments. The following two line code is copied from the page linked above, but returns the errors shown below when ran thru my Lumerical FDTD:
      a=linspace(0,2*pi,9);
      write("testfile.txt",num2str(a), "overwrite");
      Error: prompt line 2: write can have at most 2 argument
      Error: prompt line 2: argument list for write command is incorrect
    • Kyle
      Those lines run without error for me with release 2021 R1.4, please try updating your software and running the commands again.
    • mfeinst
      Okay, good to know. Will try that. Thanks
