June 16, 2023 at 2:38 pm
June 16, 2023 at 7:59 pm
Guilin Sun
Ansys Employee-
June 17, 2023 at 2:29 am
yunchen Long
SubscriberMy test frequency is between KHZ and GHz, can it be realized? Thanks
June 19, 2023 at 2:35 pm
Guilin Sun
Ansys EmployeeYes, it whould work. But it will needs long simulation time if the mesh is too fine. Now the wavelength is in cm or meters so mesh/simulation time much be proper. Usually the default settings should be modified.
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7592
4440
2953
1427
1322
