March 11, 2021 at 1:49 am
Lito Yap
Ansys EmployeeError: Failed to checkout feature... FlexNet licensing error:-15nProbable cause:nNetwork Connectivity - not able to connect with the license server.nFirewall / Security restrictions - not allowing traffic on ports used by the license manager. nTo resolve:n(1) If accessing from a different computer, consult with IT to ensure that your computer can connect with the license server machine.n(2) On firewalled/secured networks, configure license server with static ports.nSERVER server_hostname 001122334455 1055nVENDOR ansyslmd port=1056nWith static ports specified (shown above), add these ports to your exception list: 1055, 1056 and 2325 to allow server communications. See license server configuration for details.n(3) Ensure that the license configuration is set to the correct license manager, server and port. nConsult with IT or license server administrator for these information. nn
March 15, 2021 at 9:14 am
Keyur Kanade
Ansys EmployeeThanks!n -
March 16, 2021 at 2:18 am
tgartner
SubscriberHello, nI am running into this problem currently. My group at university has a floating license which I am trying to access at home via the IP of the computer the license is hosted on. But i run into this error. Is there anything I can do on my end at home to remedy this? I have confirmed the machine with the server is running and the IP is correct. Do i need the license server software on my computer as well?nn
March 16, 2021 at 2:40 am
Lito Yap
Ansys Employee,Your home computer and University network are not on the same local network (LAN). Consult with your university's IT department on how you can connect from your home computer to the license server on your university's network. -
March 16, 2021 at 7:57 pm
tgartner
Subscriber@tgartner, Your home computer and University network are not on the same local network (LAN). Consult with your university's IT department on how you can connect from your home computer to the license server on your university's network.https://forum.ansys.com/discussion/comment/110973#Comment_110973
Thank you. Are there any specific settings in the license manager software they will have to change to allow me access?n -
March 16, 2021 at 8:19 pm
Lito Yap
Ansys Employee,not on the license manager software but IT will have to allow network connectivity/access between your home network and your university's network on ports used by the license server.n -
March 16, 2021 at 8:48 pm
abacker
SubscriberHi Lito,nI am trying to configure flexnet/ my Lumerical FDTD license for the first time (on a MacOS computer). Is there any way that I can schedule a time to speak over the phone with someone from Lumerical to help me get this set up? Thanks for your help.nAdamn -
March 16, 2021 at 9:02 pm
Lito Yap
Ansys Employee,Note that support for MacOS ended with 2020 R2 release. We will be contacting you directly. n
- Workbench error
- Workbench not opening
- License Error
2656
2120
1349
1118
461
