January 23, 2022 at 2:17 pm
ur21581
SubscriberHow to run Lumerical file on HPC (Linux), please?
I have problem with submitting my job script.
Lumerical module installed on the HPC system is called:
apps/lumerical-fdtd/2021-r2
Please see attached screenshots...
January 24, 2022 at 6:20 pmLito Yap
Ansys EmployeeCan you paste the screenshot/image into your post? We are not allowed to download files from the forum. Thank you.
January 24, 2022 at 6:48 pmur21581
SubscriberThank you, Lito.
What is the difference between:
fdtd-engine-ompi-lcl
and
fdtd-solutions
please?
(We want distributed computing instead of parallel computing, multiple processors performing one just one job.)
What is the command for running: fdtd-solutions, please?
The command for running: fdtd-engine-ompi-lcl is:
mpirun -np $SLURM_NTASKSfdtd-engine-ompi-lcltest.fsp
January 24, 2022 at 6:50 pmur21581
January 24, 2022 at 10:28 pmLito Yap
Ansys Employee"fdtd-solutions" is the CAD/GUI component of FDTD. This is run/executed from your Desktop/Graphical environment which requires a GUI/graphical connection on the Linux machine. Typically on clusters, you do not have GUI access/graphical connection. You run the simulation file from the command prompt using the solver/engine component of FDTD.
cd /path_of_your_simulation_file/
module load openmpi #load your OpenMPI
mpirun /opt/lumerical/v221/bin/fdtd-engine-ompi-lcl -t 1 yoursimulationfile.fsp
February 2, 2022 at 3:45 pmur21581
SubscriberThank you, Lito!
February 3, 2022 at 12:01 amLito Yap
Ansys Employee,You are welcome.Viewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to move duplicated ansys project position in workbench GUI
- unable to open files in ansys
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Error: Unable to open some designs in this project – Corrupted project files
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- ANSYS Multi field 2-way FSI data coupling issue
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
5428
3391
2471
1310
1022
