Ansys Products
Ansys Products
Lumerical install MPI fail
    • Albi.Pani
      Hi, I am trying to install lumerical and it gives me this error, I have tried to turn off windows firewall and anti-virus but nothing
      Component Intel MPI Runtime (2019 Update 10) has failed to install with the following error message:
      "A failure occurred attempting to install Intel MPI Runtime."
      The following components were not installed:
      - Microsoft MPI (10.1.12498.16)
      The following components failed to install:
      - Intel MPI Runtime (2019 Update 10)
      See the setup log file located at 'C:\Users\Utente\AppData\Local\Temp\VSD3486.tmp\install.log' for more information.
      In install.log I have
      The following properties have been set:
      Property: [AdminUser] = true {boolean}
      Property: [InstallMode] = HomeSite {string}
      Property: [NTProductType] = 1 {int}
      Property: [ProcessorArchitecture] = AMD64 {string}
      Property: [VersionNT] = 10.0.0 {version}
      Running checks for package 'Intel MPI Runtime (2019 Update 10)', phase BuildList
      Running MsiProductCheck with ProductCode '{CC3B8EBC-061F-4A14-9126-3476836F367E}'
      MsiQueryProductState returned '-1'
      Setting value '-1 {int}' for property 'IsMsiInstalled'
      The following properties have been set for package 'Intel MPI Runtime (2019 Update 10)':
      Property: [IsMsiInstalled] = -1 {int}
      Running checks for command 'intel_mpi_runtime\w_mpi-rt_p_2019.10.321.exe'
      Result of running operator 'ValueGreaterThan' on property 'IsMsiInstalled' and value '0': false
      Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false
      Result of checks for command 'intel_mpi_runtime\w_mpi-rt_p_2019.10.321.exe' is 'Install'
      'Intel MPI Runtime (2019 Update 10)' RunCheck result: Install Needed
      Running checks for package 'Microsoft MPI (10.1.12498.16)', phase BuildList
      Running check with folder 'C:\Program Files\Microsoft MPI\Bin\' and file 'mpiexec.exe'
      Unable to find directory 'C:\Program Files\Microsoft MPI\Bin\'
      Not setting value for property 'MPIVer'
      The following properties have been set for package 'Microsoft MPI (10.1.12498.16)':
      Running checks for command 'MS-MPI\msmpisetup.exe'
      Skipping ByPassIf because Property 'MPIVer' was not defined
      Result of checks for command 'MS-MPI\msmpisetup.exe' is 'Install'
      'Microsoft MPI (10.1.12498.16)' RunCheck result: Install Needed
      Installation of components 'Intel MPI Runtime (2019 Update 10), Microsoft MPI (10.1.12498.16)' was accepted.
      Copying files to temporary directory "C:\Users\Utente\AppData\Local\Temp\VSD3486.tmp\"
      Copying from 'C:\Users\Utente\Desktop\Lumerical_Suite\intel_mpi_runtime\w_mpi-rt_p_2019.10.321.exe' to 'C:\Users\Utente\AppData\Local\Temp\VSD3486.tmp\intel_mpi_runtime\w_mpi-rt_p_2019.10.321.exe'
      Verifying file integrity of C:\Users\Utente\AppData\Local\Temp\VSD3486.tmp\intel_mpi_runtime\w_mpi-rt_p_2019.10.321.exe
      WinVerifyTrust returned 0
      File trusted
      Copying from 'C:\Users\Utente\Desktop\Lumerical_Suite\MS-MPI\msmpisetup.exe' to 'C:\Users\Utente\AppData\Local\Temp\VSD3486.tmp\MS-MPI\msmpisetup.exe'
      Verifying file integrity of C:\Users\Utente\AppData\Local\Temp\VSD3486.tmp\MS-MPI\msmpisetup.exe
      File trusted
      Running checks for package 'Intel MPI Runtime (2019 Update 10)', phase BeforePackage
      File trusted
      Installing using command 'C:\Users\Utente\AppData\Local\Temp\VSD3486.tmp\intel_mpi_runtime\w_mpi-rt_p_2019.10.321.exe' and parameters ' --s --log intel_mpi_runtime\intel_mpi_runtime.log --extract-folder intel_mpi_runtime --remove-extracted-files yes --a install -eula accept --output=intel_mpi_install.log  --installdir="C:\Program Files (x86)\IntelSWToolsMPI" --intel_sw_improvement_program_consent=no '
      Process exited with code -1073740571
      Status of package 'Intel MPI Runtime (2019 Update 10)' after install is 'InstallFailed'
      Status of package 'Microsoft MPI (10.1.12498.16)' after install is 'InstallNeeded'
    • Lito Yap
      If you have Visual Studio installed on your computer, this will cause Intel MPI to fail and crash during the installation process.
      Install Lumerical and Microsoft MPI manually on your computer as shown in the Knowledge Base (KB)
      >>> https://optics.ansys.com/hc/en-us/articles/5535727473811#toc_3
      Do not install Intel MPI using our bundled installer. Run the simulation using the default Job launching preset, Microsoft MPI.
