Tagged: core, lumerical, Lumerical-FDTD, photonics, simulation
February 26, 2022 at 6:05 pm
mm_candela
SubscriberHello
February 28, 2022 at 8:15 pmLito Yap
Ansys EmployeePlease see this post in the forum on how to obtain the optimum resource configuration for your simulation on your computer. Se also: FDTD Performance Benchmarks and Information on Hardware Specifications.
- Error on Lumerical device
2726
2148
1359
1150
462
