March 4, 2021 at 4:41 pm
Chris Kopetski
Ansys EmployeeLumerical support registration is a simple process that allows Lumerical users to access commercial technical support and some technical resources such as Application Gallery files.
NOTE: Technical support for commercial customers is provided via Lumerical support, not the Ansys customer portal. Support is valid for the duration of your license/subscription. Once the license expires, you will have to register for support with your current license. A Lumerical user account and an active Ansys Lumerical license is required to register for support.
Please see this guide in the Lumerical Knowledge Base (KB) for details. -
July 14, 2022 at 10:03 am
ghumro.adnan
SubscriberDear Lumerical Support Team,
Greetings
I am Adnan, Masters student at Scoula Superiore Sant'Anna. I am using Lumerical to simulate some part of my masters thesis. I am using a components from Extruded Polygons and particularly isosceles Trapizoid. I am rotating it's first axis along y axis by 90 degree and second axis along z axis. I am intersted that the trapizod lx top and lx base should increase along the z axis like taper for example at start the lx base is 0.48 and lx top is 0.40, but it should gradually increase untill 10um in z axis and ends up with 1.5um top base and 1.40um. I am not able to do it, so I need your help to figure out how we can acheieve this in Lumerical.
Looking forward to hear from you
Thank you
Best Regards,
Adnan
Scuola Superiore Sant'Anna, Italy
September 10, 2022 at 7:24 am
Yamato Takano
Subscriber間違えました。
September 20, 2022 at 7:26 pm
jic
SubscriberHi I am Cheng who is a UChicago student. Recently I am running a 1D nanobeam cavity simulation. However, after I ran it a few times, I found the signal always has some divergences as time evolves. Sometimes it leads to a warning but sometimes it just bumps up a little, but overall either one does not make any physical sense. Could you please help me take a look at it, to see if I made something wrong with the simulation setup? Best Cheng -
October 12, 2022 at 9:42 pm
Shing Lee
SubscriberI have already registered.
October 15, 2022 at 7:46 am
Humaira Zafar
Subscriber -
December 29, 2022 at 3:09 am
Kenneth Arnett
SubscriberGreetings!
I would like some technical support over the phone please
I am a registered user that does not want to broadcast their company affiliation
Please contact via Ansys email
Kenn Arnett
January 10, 2023 at 10:01 pm
Lito Yap
Ansys Employee@Kenneth Arnett,
- Sign up/register on the Ansys Lumerical website.
>> How to create or update your Ansys Lumerical user account – Ansys Optics - Register for support with your current Ansys Lumerical license.
>> How to register for support with Lumerical – Ansys Optics - Then you can submit your technical support request with Ansys Optics Support
>> Ansys Optics – Support
- The topic ‘Lumerical support registration instructions’ is closed to new replies.
- Error on Lumerical device
3702
2564
1771
1236
592
