April 14, 2022 at 7:37 am
pengzheng97
SubscriberI need to use the lumopt with complex index, but meet some problems
CONFIGURATION FILE {'root': 'D:\Program Files\Lumerical\api\python', 'lumapi': 'D:\Program Files\Lumerical\api\python'}
Initializing super optimization
Wavelength range of source object will be superseded by the global settings.
Traceback (most recent call last):
File "D:/Program Files/Lumerical/python-3.6.8-embed-amd64/fdtd-python/fdtd/JXP/Au_R.py", line 89, in
beta=1)
File "D:/Program Files/Lumerical/python-3.6.8-embed-amd64/fdtd-python/fdtd/JXP/Au_R.py", line 58, in runSim
opt.run(working_dir=working_dir)
File "D:Program FilesLumericalapipythonlumoptoptimization.py", line 351, in run
self.initialize(working_dir=working_dir)
File "D:Program FilesLumericalapipythonlumoptoptimization.py", line 97, in initialize
list(map(init_suboptimization, self.optimizations))
File "D:Program FilesLumericalapipythonlumoptoptimization.py", line 93, in init_suboptimization
cur_optimization.initialize(local_working_dir)
File "D:Program FilesLumericalapipythonlumoptoptimization.py", line 558, in initialize
self.geometry.add_geo(self.sim, start_params, only_update = False)
File "D:Program FilesLumericalapipythonlumoptgeometries opology_complex.py", line 481, in add_geo
eps = self.eps if params is None else self.get_eps_from_params(sim, params.reshape(-1))
File "D:Program FilesLumericalapipythonlumoptgeometries opology_complex.py", line 189, in get_eps_from_params
'eps_geo = topoparamstoindex(params,topo_rho);').format(self.eps_min,self.eps_max,self.filter_R,self.beta,self.eta,self.dx,self.dy) )
File "D:Program FilesLumericalapipythonlumapi.py", line 1184, in eval
evalScript(self.handle, code)
File "D:Program FilesLumericalapipythonlumapi.py", line 248, in evalScript
raise LumApiError("Failed to evaluate code")
lumapi.LumApiError: 'Failed to evaluate code'
Process finished with exit code 1
and I use the complex like this
eps_wg = (6.5+8j) ** 2 eps_bg = 1 ** 2
there is any solution to solve it?
best wish!😁
April 19, 2022 at 12:23 amTaylor Robertson
Unfortunately topology optimization doesn't currently support materials with complex indices. You could submit this as feature request to IX.
https://ix.lumerical.com
- Error on Lumerical device
2656
2120
1347
1118
461
