March 7, 2023 at 4:17 pm
schinta3
SubscriberHello,
Can the LumOpt -> Python integration and API be used on a headless node? I.e. if you are controlling LumOpt/FDTD through python scripts, can you directly call the FDTD engine to compute the generated forward and adjoint simulation as they are created into .fsp files? Or does this require the GUI connection.
Thank you
- Error on Lumerical device
3744
2573
1821
1236
596
