August 24, 2019 at 9:01 pm
shcon
SubscriberHello all,
I have a question about lumped ports in HFSS. Can two ports be on the same face of a substrate?
Thanks,
Shaynee
September 4, 2019 at 4:04 pm
slouie
Ansys EmployeeHi Shaynee,
They can, but if you're really asking whether they can overlap - the answer is no.
Hope that helps.
- Maxwell, HFSS or Q3D?
- Error
2616
2098
1323
1108
461
