TAGGED: ansys, Current-flow-line, hfss, Lumped-RLC-boundry
May 18, 2022 at 11:31 am
Badr
SubscriberHello all,
I have a problem viewing the Lumped RLC boundry window, and it doesnt show the current flow line option.
Anyone had seen the same problem before, can it be fixed?
Thanks
Badr
May 24, 2022 at 11:08 amChinmay T
Did you recently change your screen resolution settings?
If yes, please change the screen resolution settings and check whether you can view the full window or not.
Do you see the same problem with any other popup windows?
Thanks Chinmay
May 26, 2022 at 2:13 pmBadr
SubscriberHi Chinmay,
Thank you for your response.
No i didnÔÇÖt change the screen resolution, although I had tried
doing that hoping it would solve the problem but didnÔÇÖt.
This issue I only appear with Lumped RLC Boundary window.! and still dont know how to fix it.
Thanks Badr
- Maxwell, HFSS or Q3D?
- Error
3850
2609
1853
1246
600
