January 30, 2023 at 7:48 am
cbur
SubscriberHello,
One of our customers is experiencing strange error messages on some of his files (see photo)
Do you have any idea what could be the cause?
We have uninstalled and reinstalled SpaceClaim in ADMIN.
I thought at first that it was due to a deleted file, so we deleted its design and started from scratch but the problem reappeared after a few days... -
January 30, 2023 at 9:08 am
Devendra Badgujar
Forum ModeratorHello charlie
Let me check this and get back to you.
February 13, 2023 at 10:25 am
Devendra Badgujar
Sorry for the delay here. Please can you let me know when this error exactly occurs? Is it while opening the files, or while using any tool, while saving or by other means?
Any more information would be helpful to understand this problem better. Also, please send me a recent SpaceClaim log file (from the error session).
The SpaceClaim log files can be found in C:Users
AppDataRoamingSpaceClaimLog Files.
(Sometimes the AppData folder is hidden. To find it, type %appdata% into the file path and press enter)Regards.
March 10, 2023 at 10:32 am
Guillaume ANFOSSI
SubscriberHello,
I've a similar case. What is the solution ?
March 10, 2023 at 11:07 am
Devendra Badgujar
Forum ModeratorGUICAD
We would need more information to understand this problem better. Please can you let me know when this error exactly occurs? Is it while opening the files, or while using any tool, while saving or by other means?
March 10, 2023 at 11:41 am
Guillaume ANFOSSI
Subscriber 🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsUsually our cutomer recognize after closing SpaceClaim.
I already had a similar case when I selected a file in the windows explorer with the view pane active
Here is a log file.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7592
4440
2953
1427
1322
