Machine toolbook
    • Cesar0103
      Hi everyone...
      I use machine toolkit to obtain the efficiency maps of a PMa-SynRM, when simulation the machine without PM the result is correct, but I do the simulation with PM and I think that the result is no correct. I simulated the PM-SynRM as an IPM machine, I show you the result of the simalations.
      without PM
    • Navya C
      Hi @ CesarnWhich version of AEDT are you using?nThe error seems to be with Gamma - angle Between stator MMF and rotor d-axis. as it will not be the same in both cases.nHowever, please provide screenshots of your Machine toolkit setup and preprocessing steps you followed to set up the design in both cases.nAlso, include your excitation and setup details and snapshots of how your model looks with and without magnets.nnRegardsnNavyann
    • Cesar0103
      Hi Array nI do not know what the version is it, but I attach a screenshot....nStepsn 1n3nWith PMnnn2nnn4n
