Macros for unsteady statistics
    • aitor.amatriain
      In LES, I want to add a source term in a equation that depends on the mean subgrid turbulent viscosity and te RMSE of the fluctuating velocities.
      I have read the customization manual, and it seems that there are macros for the velocities
      RMS(C_STORAGE_R(c,t, SV_U_MEAN), C_STORAGE_R(c,t, SV_U_RMS), delta_time_sampled, SQR(delta_time_sampled));
      but I do not see anything similar for the subgrid turbulent viscosity. Is there any alternative?
      I can create a Custom Field Function with the variable that I want. Is it possible to use a Custom Field Function in a UDF?
      Thank you,
      Aitor
    • aitor.amatriain
      I was thinking of creating a UDS, go to Cell Zones - Fixed Values and set the value of the UDS to be equal to the source term that I want by using expressions, but I hope there is a more direct approach
    • DrAmine
      Alternative to doing that on your own (the time sampling for C_MU_T) or via Custom Field Function -> Patch in UDM every time step. (a way among other ways).
    • aitor.amatriain
      How can I patch a Custom Field Function to a UDM?
    • DrAmine
      Calculation Actitvity
    • aitor.amatriain
      I create a user-defined memory location, then I define the Custom Field Function, and what command should I execute to set the UDM to be equal to the Custom Field Function?
    • DrAmine
      You patch the content of CFF into UDM. To have the right command better to record a small journal in which you patch from TUI by using the Search Keyword Feature. It should start with /solve/patch .....
    • aitor.amatriain
      In /solve/patch I can only patch flow variables, not CFF.
    • DrAmine
      You patch an UDM using the value of CFF.
    • aitor.amatriain
      But how can I do that? There is no info in the manuals nor on the Internet in general
    • aitor.amatriain
      Update: In case it is helpful for others, after creating the Custom Field Function called cff, I did it in Initilization-Patch-udm0-cff
      Thank you for your help Amine!
    • DrAmine
      Welcome Aitor. The help does cover that but I always recommend to make use of that TUI Keyword searcher and record a journal file to have the right commans! Thanks for sharing your update.
Viewing 11 reply threads
