September 22, 2022 at 11:38 am
Vinay_G
SubscriberHello,
When we are plotting Mag_B in Ansys Maxwell. will it give data in both positive and negative or it only shows the positive values(|B|) of B field.
Thanks in Advance! -
September 26, 2022 at 2:51 am
Navya C
Ansys EmployeeHi Vinay_G,
What you get on the Mag_B plot is the Magnitude of the B distribution.
Navya
September 26, 2022 at 6:16 am
Vinay_G
SubscriberHello Sir,
Thank you, Is there any way in ansys to get the plot in both positive and negative sides?
- Maxwell, HFSS or Q3D?
- Error
2712
2146
1357
1150
462
