Discovery Import
Discovery Import
Magnet Property
    • Mojgan Ghodrati
      I am calculating the force fore repelling magnet in the attached configuration. In the first configuration magnet diameters are 4 mm and the distance between magnets is 1,7 mm. I rotate the upper magnets and the magnets are repelling (positive axial force for upper magnets).
      When I increase the magnets diameter to 5 mm and keep the rest parameter constant, the magnets at the beginning are attracting instead of repelling (negative axial force for upper magnet.)
      So when the magnets are strong and they are very close, regardless of repelling setting, magnets are attracting. Could you please tell me what is the name of this property and how can I calculate the min distance and magnet diameter in which we don't face this attraction?
      Thank you.
    • Subashni Ravichandran
      Hello Ghodrati
      Would you be able to share the model with us for a better understanding?
      I have shared an Ansys Secure Transfer link with you via email. Please use the link to share the file.
      Hello Ghodrati
      I have not received any file from you via Secure Transfer.
      If you face any difficulties in sharing the file please let us know.
      • Mojgan Ghodrati
        Hello @Subashni,  I sent the files the same day. Can you please send me another invitation?
