Preprocessing
Preprocessing
Magnetic Braking System
    • Khadijah
      I am simulating a magnetic braking system with a copper brake disc and a gray cast iron u-shaped magnet and keep receiving the following error (first photo is the initial error message and second is the actual error explained):
    • Aniket
      nTry unchecking distributed and rerunning the model.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
    • Khadijah
      Hi Aniket I have just tried this and it still didn't workn
    • Aniket
      what error do you get in the solver output file?n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
    • Khadijah
      Its in the first message I sentnn
    • Aniket
      sorry this is bit puzzling, so even if you have disabled the distributed solver by unchecking it, you still see  Distributed parallel processing will be deactivated for this solution.  error?n
Viewing 5 reply threads
