August 13, 2019 at 8:02 pm
EM_Design
SubscriberHello
I have been struggling with magnetization of a magnet in Maxwell. I apply a current and expect to see the some Remanence (magnetic field density (Br)) after removing the current. However the B goes to zero after the current. Here is the procedure I do:
from assign excitation > set magnetization computation > compute magnetized operation points > select the magnet (see attached figure).
Then run the simulation and the magnetization process is successful, however after removing the current, the curve (
goes back to zero; however in reality it should stay somewhere in the y axis (see attached figure. This would count as the magnetization state of the magnet. Does anybody know how to fix this problem?!!
August 16, 2019 at 6:40 pm
Paul Larsen
Ansys EmployeeThere are several options for magnetization. The method you are using for "Compute magnetized operation points" requires two linked models (either same or different geometry). The first simulation only calculates the peak operating points on the BH curves. In the second simulation, it will operate on the recoil lines, and needs to be set up with Permanent Magnet excitation (not assigned to an object if using same geometry, or assigned to an object with object CS if using different geometry).
Please see the Maxwell help topic "Permanent Magnet Field Excitations for 2D and 3D Transient and Magnetostatic Solvers" to look at the second step.
August 16, 2019 at 8:30 pm
EM_Design
Subscribergreat thanks. I could run the second simulation but I got more question now. I understand I have to set the permanent magnet excitation mode and set it magnetization mode. right? Now the actual question is if I need to apply any extra excitation. should I set the current that I was applying in the first simulation to zero in the second one?
August 22, 2019 at 7:17 pm
EM_Design
Subscriberstill waiting for the answer...
August 23, 2019 at 1:38 pm
Paul Larsen
Ansys EmployeeYou can use any excitation in the second model and the magnet will follow the recoil line. You can set zero excitation or any alternate excitation configuration.
- Maxwell, HFSS or Q3D?
- Error
2564
2078
1293
1106
459
