Magnetizing soft magnet (AlNiCo5)
    • adawlatzai
      I am trying to simulate a tool that involves a soft magnet (alnico5) and a bottom permanent magnet (NdFe35), currently trying to magnetize only the alnico through a pulse current so that I can map the PM field into the target model but I am unable to compute the magnetization because on Ansys it is assuming a permanent magnet. Is there something I have to change in the materials? Thank you for your time
    • adawlatzai
      The AlNiCo5 material specs
    • adawlatzai
      If I run the simulation, the AlNico gets magnetized but only for the duration the current is applied, the moment there is no current applied through the copper, the AlNiCo goes back to its original state
    • Deyu Li
      the BH curve needs to be in 2nd quadrant in this simulation.
    • adawlatzai
      Hi, Thank you for your response! Below is an image of the b-h curve I supplied on ANSYS, I think some of the curve is already in the 2nd quadrant (just to make sure we are talking about the same quadrant, I attached an image as well). Should I delete data points when it enters the first quadrant? thank you
    • adawlatzai
      sorry for the silly question, I noticed I don't supply any data points past the 1rst quadrant and that the bh curve is continuing without any data points in the 1rst quadrant, is there option to get rid of that?
Viewing 5 reply threads
