January 25, 2021 at 11:44 pm
Cesar0103
SubscriberHi everyone...nI want to get the waveform of the MMF in the air gap...Is it possible in the Maxwell?...if so, how is the procedure...nnBest regards,nCesarn -
February 1, 2021 at 8:47 am
Navya C
Ansys EmployeenYou can use Field calculator.n it can be done as the integral of H dot L where L is the length of airgap. This expression can be added to the fields calculator and can be plotted as an XY report.nnRegardsnNavyan -
February 1, 2021 at 8:57 pm
Cesar0103
SubscribernI have followed your advice but when I integrate it graphs its a point...nI am new to ANSYS and I have not used the fields calculator much, it may be that the integration is wrong...Look in the help but there is no very clear example.nnRegards,nCesar -
February 15, 2021 at 11:28 am
mshjoh017
SubscriberHi Cesar,nI am also facing the same challenge. I tried the integration but I'm getting a point. Have you been able to find a way around this?nRegards,nJohn.n -
February 16, 2021 at 3:06 pm
Cesar0103
SubscriberI tried the integral, but when I use the integral command in the field calculator it gives me an error, I have not solved that problem yet.nI do not know what I'm doing wrong.nnAny news I will comment on this linenRegards, nCesarn -
March 24, 2021 at 4:13 pm
mshjoh017
SubscriberHi @Cesar You can use Field calculator. it can be done as the integral of H dot L where L is the length of airgap. This expression can be added to the fields calculator and can be plotted as an XY report.RegardsNavyahttps://forum.ansys.com/discussion/comment/105075#Comment_105075
Hi @nchode, thanks for your response. Would you you kindly advise why the fields calculator gives an error when you try to add the 'dot' operation after inputting Quantity H and airgap length (as a line geometry)? If it's simple enough, kindly send us a screenshot of how you input H dot L in the fields calculator so we can see where we're going wrong because clearly we're struggling!nn
March 31, 2021 at 3:16 pm
Deyu Li
Ansys EmployeeQuantity > HnGeometry > Line > your_linenVector > TangentnScalar > IntegratenAdd > H_dl > OK -
April 26, 2021 at 3:22 am
- Maxwell, HFSS or Q3D?
- Error
5028
3137
2373
1306
922
