March 11, 2022 at 10:08 am
hong11
SubscriberI have a question regarding the grid attribute of magneto-optical material in the EME solver. I used the grid attribute as instructed in the magneto-optical Kerr effect tutorial, but this time in the MODE solution.
The grid attribute seems to work fine in the FDE solver, but when I switched to EME solver the grid attribute in object Tree turned gray as if it's inactive. I wonder if I can simulate the magneto-optical material in an EME solver.
March 18, 2022 at 7:38 pmKyle
As far as I know it's not possible to use the grid attribute object with the EME solver, it can only be used with the FDE and FDTD solvers. For full device simulations with the grid attribute object you will have to use the FDTD solver.
- Error on Lumerical device
2706
2142
1355
1144
462
