January 21, 2021 at 4:55 pm
jayd
Subscriber/COM,ANSYS RELEASE 2020 R2 BUILD 20.2 UP20200601 22:19:45nn *** WARNING *** CP = 0.578 TIME= 22:19:47n Element shape checking is currently inactive. Issue SHPP,ON or n SHPP,WARN to reactivate, if desired. nn *** ERROR *** CP = 1.656 TIME= 22:19:48n There is at least 1 small equation solver pivot term (e.g., at the AZ n degree of freedom of node 12321). Please check for an insufficiently n constrained model.nnI am trying to simulate a model in magnetostatics. I keep getting this error. Please help!n -
January 22, 2021 at 4:34 pm
Bill Bulat
Ansys EmployeeMake sure the entire modeled domain is a single part (i.e., it has shared topology on interfaces between separate bodies) so that the resulting mesh nodes on interfaces are used by elements on both sides of the interface. There is no bonded contact for edge flux (AZ DOF) formulated emag elements.nAnother thing is we typically make the external surface(s) of enclosures flux parallel (constrain AZ=0). This approximates the infinite extension of the surrounding domain beyond external boundaries.nnBest,nBilln -
January 23, 2021 at 5:01 pm
jayd
SubscriberI did make the enclosure a flux parallel. Also when i track down the node by id I get the node in the empty space (i.e. air) rather than on any body. Also I made the different parts of the model by slicing a single body. So is it possible for them to not have shared topologies?n
3311
2469
