Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Major mesh repair(TAU) on body
    • Hammad Khalil
      Hello guys ,
      I am working on dynamic wireless charging of electrical vehicle using Ansys maxwell 3d. I have made two coils and moved the receiving coil in vertical axis ( up and down) using perametric sweep in z axis, the simulation ran fine and no errors were produced. Now when I'm running the same simulation but now the parametric sweep is in the x- axis instead of z- axis. And as soon as I run the simulation ,the validation is all fine and after some time it's throws me an error stating " major mesh repair(TAU) on body. And its for both the transmitting and receiving coils. Can Someone tell me the reasons for this particular error and possible remedies for this?( I can share further information required in order to evaluate this)
      Hammad
    • Navya C
      Hi Hammad,
      They are not errors but just warnings. It only informs you that some mesh modification has happened(may be due to some object moment).
      I don't think you will have any issues in completing the simulation. Do you face any problems in completing the simulation and in solution convergence?
      Navya
    • Hammad Khalil
      Yes it takes a lot of time to proceed to the next stage and it almost freezes, can you suggest to me how to resolve this?Im using it for dynamic wireless transfer.
    • Hammad Khalil
      Should i make changes in the mesh of the coils and region for instance the max length of elements etc. so this warning will not appear?
    • Ivonne Marti
      Hi Hammad,
      Yes, I would suggest to check if the Region is big enough for the parametric sweep in the x- axis and apply mesh operations in all the objects.
      Regards
      Ivonne
    • Hammad Khalil
      can you please elaborate on what you mean by " apply mesh operations in all the objects", as I have already applied mesh operations on both the coils and the region.
    • Ivonne Marti
      Sure, I meant to apply mesh operations in the coils and region. Since you have already done it, you can use inside lenght based. If you still have issues, I would encourge you to contact Ansys support, since we many need to see the model and do some tests.
Viewing 6 reply threads
