March 7, 2021 at 5:21 am
bxddstl
SubscriberProfessor, ,I am a novice. I have a question .I want to create animation .
How do you show on a graph the amount of pressure at a particular x and y coordinates?I think this needs to use a three-dimensional graph, but I can't find a graph in ANSYS Fluent that uses three-dimensional coordinates to represent pressure.Could you help me solve this problem?
In the options shown in the figure below, I select Position on X Axis. Therefore, in plot, X represents direction, Y represents pressure, and X axis represents direction, so it should only represent the direction of a line, that is to say, the plot can only represent the pressure of a line. So I want to ask which line is represented?
March 7, 2021 at 12:23 pmYasserSelima
SubscriberThese are all the cells in the plane. Ignoring the y position and plotting the pressure Vs. X position. nMarch 7, 2021 at 2:07 pmbxddstl
SubscriberProfessor, you're saying that x and y are positions, and the density of the dots is pressure, right?nThank you for your help.?.nMarch 7, 2021 at 2:32 pmYasserSelima
SubscriberNo, this not what I meant. Sorry if you understand it like this.nIn this plot, X axis is the x.position of each point and Y is the pressure of the point. y.position is not present in this figure.nWhat I tried to say in my earlier comment is that what you see in the figure is not a line. These are discrete points. Every cell in the plane-7 is represented by one point in this figure. nMarch 7, 2021 at 11:50 pmbxddstl
SubscriberProfessor, you're saying that every point on an y axis of plot means every point on the y axis of one x position in the object,but y position will not display,right?nThank you for your helpnMarch 8, 2021 at 12:42 amYasserSelima
SubscriberIf I understand you correctly, yes. All the points at the same x location on the plane, appear on one point in the chart because they have the same pressure. nMarch 9, 2021 at 2:00 pmbxddstl
SubscriberProfessor,I have another question. In the pressure plot, the vector is dense in some places and sparse in some places, so what does the density of the vector mean?Because the color represents the pressure,the density can not represent the pressure.nAnother question is that in the temperature plot, a small part of the temperature is red color. According to the color -- temperature bar, red represents 1.21e+03, that is, 1210 K. This is obviously impossible.I want to ask why?n
Thank you for your help.n
March 9, 2021 at 2:21 pmYasserSelima
SubscriberFluent creates one vector for every cell. So, the density means there are finer mesh in this area. If you want to see the pressure, select contours of pressure .. now the colour represent the pressure.nnFor the temperature, this means something is wrong ... may be not converged solution.nMarch 9, 2021 at 2:21 pmYasserSelima
SubscriberWhat is the maximum temperature in your system?nMarch 10, 2021 at 2:06 ambxddstl
SubscriberProfesser,I don't not the maximum temperature. But the inlet flow temperature is 313k and is the maximum temperature the I imoprt to the system. nThank you for your help. nMarch 10, 2021 at 2:46 amYasserSelima
SubscriberThis means your solution did not converge. Can you plot the residuals? nViewing 10 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
