March 1, 2022 at 6:17 pm
Isar
SubscriberHi,
I am trying to draw a vial with thickness and I started with the sketch and make the vial. Then I add thickness to it by thin option. Now I am at the place which I need to make this cone into curve you can find the image. Would you please guide me through?
March 1, 2022 at 6:17 pmViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
