December 20, 2022 at 11:30 pm
Willian Nunes
SubscriberBoa noite pessoal, sou novo e quero obter informações de como criar uma malha computacional CFD 3D de duas placas planas aquecidas para simular convecção natural no Fluent
Existe algum caminho que possam me ajudarMuito obrigado
December 22, 2022 at 1:15 pm
Nikhil Narale
Ansys EmployeeHello,
I can think of two ways to create a computational mesh for your application:
1: Include both fluid and solid domain: You can mesh both the solid plate and the fluid region, if you want to solve for conduction in solid along with the convection (CHT). In this approach, you can see the temperature distribution in the solid body i.e., the flat plate.
or
2: Just include the fluid domain: You can just mesh the fluid domain and give temperature/heat flux as the boundary condition.
If you are new to meshing, I would recommend you to go through this free comprehensive learning track on meshing using the Ansys Fluent Meshing Watertight Workflow: Ansys Fluent Meshing Watertight Geometry Workflow - ANSYS Innovation Courses
Thank you!
Nikhil
December 23, 2022 at 11:08 am
Willian Nunes
SubscriberBom dia senhor Nikhil, muito obrigado pela ajuda, meu caso é como citado pelo tópico 1, irei verificar as instruções de geração de malha que fez...
Muito obrigado pela ajuda
December 23, 2022 at 11:18 am
Nikhil Narale
Ansys EmployeeGreat. Let me know if you need any futher help!
- Workbench error
- Workbench not opening
- License Error
2564
2080
1299
1106
459
