March 26, 2021 at 3:42 am
AnsysFreak
SubscriberHi ??? ? Can anybody give me some guidance ? I reinstalled almost 10 times .. but st.ill get the same error msg stating uninstall.dat file not found.
March 26, 2021 at 11:52 amANSYS_MMadore
Ansys EmployeePlease make sure you extract the downloaded .zip file and run the setup.exe from the extracted files. Typically this error occurs if installing directly from the .zip file.nMarch 27, 2021 at 12:29 amAnsysFreak
SubscriberYes sir. I extracted the zip file which I downloaded from Google Chrome. By right click Extract all to c:\temp folder .. next I right click to run as administrator .. the installation directory should be c:\program files ? Or other installation directory? nMarch 27, 2021 at 2:11 amMarch 27, 2021 at 2:17 amMarch 27, 2021 at 3:17 amMarch 29, 2021 at 12:02 pmANSYS_MMadore
Ansys EmployeeArrayOnce it completes installation and you click Next it has the install.err file. Please share the full contents of that file.nViewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- Error with workbench SceneGraphChart
- Workbench error
- Workbench not opening
- License Error
2656
2120
1349
1118
461
