December 18, 2017 at 4:59 pm
December 18, 2017 at 11:49 pm
December 20, 2017 at 4:34 pm
bushrar
SubscriberUnfortunately since I have version 17, I could not open the file. So the gist of it was that you drew a sketch of the body outline?
December 20, 2017 at 5:14 pm
SubscriberYes, but I added some symmetry constraints so the points would stay on the planes. Do you have 17.2?
December 20, 2017 at 6:44 pm
bushrar
SubscriberI have version 17.0. It should still work the same there, right?
December 21, 2017 at 12:46 am
SubscriberHere is my video recorded using 17.2
June 28, 2018 at 8:37 pm
FrankD
Ansys EmployeeIn SC, when you use an annotation dimension (forced to be in a plane) accessed in the Detail tab, you can dimension between the cones:
A Pull of geometry (here the vertex at the apex of one of the cones) can change the geometry directly (offset or in a direction by some amount):
Or by linking the pull to an existing annotation dimension with the spark that shows up:
Allowing the Linear Pull to be driven by the Angular annotation dimension.
This can be stored as a reusable Group (Ctrl-G):
And perhaps more interestingly, can also be used to drive Pull and Move amounts to solve some desired Mass Property (here Volume drives the linear Pull):
The trick there is to make sure to select the desired mass property while the pull dimension is active.
F
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2642
2110
1335
1112
461
